maico996
Not necessarily flawed...just old, clunky, sometimes unresponsive.how do you know the UI is flawed ?
AFAIK the problems arise when running single ended out of a balanced jack. Balanced (with adapter) out of single ended is fine. Both channels use the common ground.Slightly off-topic but I wanted to address the Astell & Kern crowd. I've just ordered an Astell & Kern PEE 51 dongle dac, it's 3.5 single ended output. My question is... would using a 3.5 mm male single ended to 4.4 female balanced out adaptor have any negative affects upon the dac?
Thank You and kind regards in advance.
Thank You most kindly for your replyAFAIK the problems arise when running single ended out of a balanced jack. Balanced (with adapter) out of single ended is fine. Both channels use the common ground.
Yes, it candoes sr25ii can use as bluetooth receiver?
what means use tidal off-line? you can listen music without internet connection or how it works?Received my SR25 2 weeks ago. Use it mostly with Tidal off-line and balanced. Great battery. Was coming from a Dragonfly Cobalt. The 2 big differences are to be away from the phone and INTO the music and the 2.5mm balanced that has more punch and texture. Anyway great device
With the Tidal built-in app you cannot use Tidal off-line but if you install Tidal through the Open APP Service you'll be able to use it off-line (without internet connection).what means use tidal off-line? you can listen music without internet connection or how it works?
so ,use off-line means listen downloaded music from tidal?correct?With the Tidal built-in app you cannot use Tidal off-line but if you install Tidal through the Open APP Service you'll be able to use it off-line (without internet connection).
From twister6 Review : "You need to download APK file (use a site like https://apkpure.com/), copy it to Open Service Folder located on internal storage, go to Services on the DAP, and when you see the app being recognized and listed in there – click to install it. Keep in mind, for example, you will have to install Tidal apk if you want off-line downloads. Also, installed apps will not be updated automatically since you are not running Google Play. You will have to keep track of app updates and manually download and install new versions."
It happened the same to me too. I ordered a new battery from Aliexpress and replaced it myself. You will need to tools for screws. It's quite easy. Just have to be a bit more careful when you connect the battery to the part. It could get loose.My SR25 died yesterday. It started to behave strangely with the battery diminising at a very fast pace. Then I realized that the battery had grown and opened the back. It has lasted almost exactly three years with pretty intensive use part of the time.
The player still works but according to the battery now in view I should not use it.
Anybody with experience in battery change in Europe? I believe Astell gives the service. Anyone with any other experience? Thanks in advance
