The XAPK installer does not show up in the Services menu either once I place the file onto the device. Hmmm.
Are you using the 'Rush wars installer' one? This is the one that we were instructed to use on the Cube thread.
It does, you juste need to look for the following APK build: «armeabi-v7a »
Here’s the latest I use: https://m.apkpure.com/spotify-music/com.spotify.music/variant/8.5.58.954-APK
I'm really interested in reading your opinion, especially the synergy with Andromeda and Solaris (I've both too). From where did you order yours?I’m going to compare mine when it arrives to my:
N8
Lpgt
Wm1z
Sp2k
N6ii e02
Using Sony z1r, andromeda and Solaris. Obviously it’s cheaper than the others but if it gets close I may sell one of them off.
What iems or headphones have you guys paired with your so far?
Yes, the sideloaded apps bypass the Android SRC and play back in full resolution, including Tidal Masters.
I really do love the sound of the SR15 and probably will purchase the SR25. However, if this device bypasses Android SRC, then why does Amazon music report the device’s capability as a max 24bit 48khz even when the track quality is reported to be 24bit 96khz? The Hiby R6Pro reports its device capability as 24bit 192khz and it definitely bypasses SRC. This particular song is from Iggy Pop’s The Idiot album which is 24bit 96khz on Amazon Music HD.
@JasonNYC Might confirm it but I remember seeing other such issues linked to Amazon Music HD on A&K DAPs.
is the issue linked to Amazon Music HD... OR is Amazon Music HD the only app that actually tells you what the effective output is. Tidal and Qobuz do not reveal that. I have a feeling that the player is not bypassing Android SRC. now I have two (2) DAPS (ZX-507) that do this![]()
Could be. I prefer Qobuz anyway but just thought I would try Amazon HD for a month since a lot of people rave about it. I had also heard that Amazon HD stopped up-sampling everything to the max resolution off the DAP and thought I would check it out. I’m still preferring Qobuz though and it is the one I will stick with.@JasonNYC Might confirm it but I remember seeing other such issues linked to Amazon Music HD on A&K DAPs.
