Astell&Kern SA700 - Past meets Present
Feb 7, 2024 at 8:15 PM Post #691 of 705
https://hartaudiocables.com/collect...s/pc-line-interconnect?variant=44043000348893 there 2.5 trrs does that look right for this player balanced? i thought i heard this player uses differnt plug?
ok - so I have never done this before but here is my attempt at the rock eq that the link I shared has
I don't play with eq much preferring a neutral sound for classical
If you don't like it it should be easy to open up and modify in the UI
I had to add a .txt. extension to the filename so change the name to Rock.dat before copying it to your player
Bon Chance !
  • Rock.dat.txt
Feb 8, 2024 at 10:45 PM Post #698 of 705
anyone know of anywhere to get it repaired besides Astell&Kern i mean probably take forever getting shipped to Korea
I sent my SR15 to them in California, and they shipped it to Korea the turn around wasn't too bad. If it is just the battery they might be able to do it state side and that would be quicker - ask Jason he seems very helpful
Feb 10, 2024 at 4:43 PM Post #700 of 705
i put my sa700 up for sale its the 30th anniversary edition with case,i must have left it on and let battery go dead, because it works fine now, no fast battery drain or anything, i left it on idling all day yesterday it went from 100% to 98% in like 10 hours sounds awesome, but just lack of ability to install a android music player , kills it for me, i love Poweramp...lol
Feb 27, 2024 at 11:39 PM Post #701 of 705
SA700 - New firmware update! Out of the blue!!
What was in the update?
Does anyone know the which of the latest Tidal, Qobuz app versions will now work with the SA700?
Also, is the SA700 able to install Roon or Roon Arc or is that a permanent no due to its architecture?
Thanks
Feb 28, 2024 at 3:06 PM Post #702 of 705
Thanks
- Fixes a bug where year could not be set past 2023 in date/time setting.
- Fixed issue with connection of AK CD Ripper MK II to SA700
- Various system stability and bug fixes
Since the underlying version of Android OS was not updated, the latest Tidal, Qobuz and Roon apps that only support newer Android versions will not be supported.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Feb 28, 2024 at 8:37 PM Post #703 of 705
Feb 29, 2024 at 5:51 AM Post #705 of 705
My SA700 updated a couple of days ago, see pic.
I can't find any information about it.
Shame they can't update the android version with this model.
To date AK was never known to provide update for the Android version of their players including those on their top tier models.
