briedfox
Maybe I missed this, after searching this thread, but is the battery replaceable? I would hate to think that this could be an expensive paperweight a few years down the road. Thanks...
BTW, I asked Bloom Audio about this about this and they stated that they didn't know for sure but they imagine AK would replace the battery for this since they allow it for all of their DAPs.I don't think that the battery is replaceable, but here's why I think that might be okay:
In my use, I probably use the PA10 for about 12 hours a week -- a little less than 2 hours per day. 12 hours (or 1 week) equates to about 1 battery charge.
If I assume that the battery can be recharged as many times as an iPhone battery (which is supposed to last about 2 years with daily charges) then I'd have 730 charging cycles (365x2).
If I'm charging once a week on average, then I'd have roughly 14 years of use of the PA10. By that time, I'll be happy to justify purchasing a new amp!
But, even when the battery reaches the end of its recharging life, I presume that the PA10 will operate when plugged in to a wall power outlet--so it becomes a stationary amp.
And, perhaps Astell &l Kern will have (if they don't already) a battery replacement program in the future.
Thank you for posting this, Noire is in my watch list too.My PA10 arrived today and I had a listen for a couple of hours. I started with my FiiO M11 Plus LTD using the 4.4mm line out into the PA10 with AuR Audio Neon Pro IEM which sounded fabulous. It seemed like the sound was immediately more dynamic than straight off the M11 Plus, a combination that I had previously been listening to for about 8 hours while working,
I moved to my Shanling M3 Ultra, since the M11 needed charging, and HD600, also using the 4.4mm and the HD600 sounded as good as I have heard them on any amplifier. Sounds were very crisp and impactful and seemed to be more pin point isolated than off my iFi Diablo that I usually use with the HD600.
I had a quick listen with Dan Clark Aeon Noire planars which also sounded great. The Aeon need quite a bit of power but the PA10 drove them effortlessly. I tried the different current settings and the higher current settings seemed to give the bass a touch more authority but to be honest that might have been expectation bias.
The PA10 had a touch of soft hiss with my most sensitive IEM but to be honest it was not intrusive at all, notably quieter than an iFi Go Bar and I believe also quieter than the iFi Gryphon by way of comparison.
It doesn’t have anything like the power of the iFi Diablo but it still has plenty.
That volume pot is an absolute pleasure to use.
I am very happy so far and while still not cheap I think it represents good value. It is beautifully made and a pleasure to use.
I asked about 4.4mm interconnects earlier but didn’t get a reply. For anyone that might be interested I used a Forza Audioworks cable that has all five terminals connected, a ddhifi cable that also uses all five terminals and a GUCraftsman cable that only uses the four terminals with the ground omitted. All three worked perfectly so any number of more cost effective 4.4mm to 4.4mm cables would work with the PA10, I know there are several makers on Aliexpress selling much more reasonably priced 4.4mm to 4.4mm interconnects.
I've used pa10 stacked with sa700 dap while streaming tidal- all good. No issues when stacked with hm1000 dac in bt receiver mode either.Appreciate everyone's postings on their usage experiences with their PA-10s.
I was wondering if anyone does much music streaming with their PA-10 in a stack with a DAP in a streaming scenario.
I was thinking of combining the amp with a Shanling M6 Pro or FiiO M11 Plus ESS using bal 4.4mm but wanted to know if anyone had had a similar set-up and could comment on any possible RF noise leaking into the audible range.
Thanks for any info!
