Astell&Kern Launches KANN ALPHA Digital Audio Player
Jul 23, 2021 at 11:46 AM Post #1,459 of 2,133
Wrong specs, KA works only with *2.4ghz
Like twenty years ago ... but It's nearly working in my office with 2.4/5ghz wifi .. at home with some MESH and Wifi 6 in the environment.. I can only use an android 10 smartphone sharing my wifi to avoid drops.
Jul 23, 2021 at 2:14 PM Post #1,462 of 2,133
If anyone's interested here's a quick video I made of the issues I'm having with wifi and offline using Qobuz
Jul 24, 2021 at 1:11 AM Post #1,463 of 2,133
Have anyone tried side-loading Apple Music 3.6.0 APK with Kann Alpha?
Choppy music is played when I play a 24-bit 192kHz song (FYI It is Coldplay - the scientist)
I have no more problem so far other than this.
Just tried that song, and yes, I experience what you describe. I did, however, just listen to the Ben Harper album Burn to Shine in it‘s entirety without issue.
Jul 28, 2021 at 12:42 AM Post #1,465 of 2,133
I gave up with Qobuz and I'm now trialing Apple Music, works flawlessly with my Kann Alpha, but is there not a way to stream 24/192 via the APK to the Kann? Would you really have to have an external dac with the Kann. Not saying I can tell the difference between 24/96 and 24/192 but curious regardless
Jul 28, 2021 at 5:12 AM Post #1,466 of 2,133
The latest APK from apkpure.com streams 24/192 natively.
Jul 28, 2021 at 5:42 AM Post #1,467 of 2,133
Probably one of the rare things working correctly with the Kann Alpha .. with the latest qobuz apk, I get the correct 24/192 out of Qobuz through the optical output.
Jul 28, 2021 at 12:49 PM Post #1,468 of 2,133
Just an update on this. I turned off bluetooth and this fixed the issue (even though I wasn't using it).
I have tried it again without turning on the Bluetooth. And, it didn't help. 😭
However, when I turn off the WiFi, it gets better for a while(for about a minute).
Then, I tried to download the song and play it offline. The problem still exists.
Jul 28, 2021 at 8:28 PM Post #1,469 of 2,133
Do you mean the apple music APK or Qobuz? I got Qobuz to do 24/192 but my issue what I couldn't stream any hires despite having giga bit internet, it would play for 5 seconds then buffer.
