pajjap
- Dec 8, 2015
Would there be new official updates for the tidal and qobuz or do we have to rely on sideloading apps?
Qobuz is so slow it’s essentially not usable.Anyone with issue with lag with qobuz? No issues with song stuttering, thankfully. It’s just that typing in the search bar can be a little frustrating.
After the new update (8.1.1.0) the Qobuz became extremely slow. It seems the new version is too heavy for the weak hardware of Kann Max. This version is a disaster and almost bricked my KM.Anyone with issue with lag with qobuz? No issues with song stuttering, thankfully. It’s just that typing in the search bar can be a little frustrating.
That sucks. If only qobuz would try and optimize it, though I’m sure they won’t.After the new update (8.1.1.0) the Qobuz became extremely slow. It seems the new version is too heavy for the weak hardware of Kann Max. This version is a disaster and almost bricked my KM.
The posts today are the first I am hearing about this. I will follow up with the dev team and get back to you.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
I have the version that’s with the latest update. That’s where I noticed the lag. Is there an upcoming update too for the latest tidal app?The posts today are the first I am hearing about this. I will follow up with the dev team and get back to you.
I assume the previous version of the Qobuz app was ok and did not have any of the same issues you are experiencing with 8.1.1.0?
Hi @anandgiridhar
There is a bug in the Roon Arc app. In order to update it, you will need to delete the currently installed app and install the new version. Unfortunately that will erase any downloaded content and settings for the Roon Arc app. This will not affect any other app. To delete the app, you will need to click on the icon next to the Roon Arc app and select delete from the menu. Roon is aware of the issue we are experiencing and is working on a fix.
I believe there is also an issue with the Spotify app and we are expecting an updated version to be added to the download tab sometime in the next week.
Thank you for letting me know. New app updates are going to be pushed out around the first week of January according to the current schedule. I will check to see if they can be pushed out sooner.@JasonNYC
This spotify download update is still a problem as of last week (and so is Roon, though not as important). The installation does'nt work with error parsing the package. Request if you can ask the app team to please check. Thanks a lot.
SW in AK Kann Maxx is very pathetic. Even getting a stable wi fi connection is not possible.I picked up the Sennheiser momentum 4 wireless earbuds but was unable to get them to pair, they were not even discoverable.
Is it even possible to get wireless earbuds and the Kaan Max to play together?
Thanks for the info.SW in AK Kann Maxx is very pathetic. Even getting a stable wi fi connection is not possible.
Thanks a lot, @JasonNYC !Thank you for letting me know. New app updates are going to be pushed out around the first week of January according to the current schedule. I will check to see if they can be pushed out sooner.
