Astell & Kern Kann MAX
Jun 17, 2023 at 3:22 AM Post #466 of 553
Ok, that is odd. And presume Auto Sleep has a high value more than say, 30min. or is set to "Always turn on", or something like that? Same with Auto Power Off?
Really I dont know no long exactly. I use player to burn iems sometimes. Not ususal on other brands and I think that is a bug than must be solved. I have autoswitch off and hibernation off. On images ( on spanish but easy to read) you can see configuration.
Jun 17, 2023 at 4:11 AM Post #467 of 553
Looked up the Spanish translation, seems to me ok. Quite odd. Maybe somebody else or someone from AK can help.
Really I dont know no long exactly. I use player to burn iems sometimes. Not ususal on other brands and I think that is a bug than must be solved. I have autoswitch off and hibernation off. On images ( on spanish but easy to read) you can see configuration.,
Jun 17, 2023 at 1:58 PM Post #468 of 553
Question. After playing some songs and if I dont touch the player the songs stop. Player is on but music stop, why?
Try a soft reset. Could be an issue with a stuck background Android process causing the music to stop.
To soft reset, while the player is on, press and hold the power button for about 10 - 12 seconds until the player shuts down. Release rhe power button, then press it again to restart the player.
The other issue may be a corrupt or unsupported file on the player or on microSD card. If there is a file that cannot be indexed due to corrupt or a non supported file type, the player will continue to try to scan and index it in the background. That could also cause the player to exhibit random crashes or stoppage of play.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Jun 17, 2023 at 4:11 PM Post #469 of 553
I tried but not solved. Waiting total scan of sd.
Jul 2, 2023 at 5:19 AM Post #477 of 553
Hi. After more of one month using Max I have two issues. Bluetooth is bad on ldac using btsink with smpartphone Samsung (with cuts) and player app problems with continuous play. On Poweramp you have that option but not available on AK app. No more problems for me and very happy with it. I hope these issues were solved.
Jul 11, 2023 at 10:31 AM Post #478 of 553
@JasonNYC or anyone who uses Apps on the Kann Max
For apps like Apple Music, Spotify, Tidal etc. do we have to obtain the APK from some site? Or is it like I read in some other (newer) AK players, where the App is downloaded from an AK server?
If we have to download, is there any specific recommended mechanism like using google play or APKPure, or any specific versions that will work?
Some general or input on how this works would please be helpful, thanks
Jul 11, 2023 at 11:19 AM Post #479 of 553
Go to services
