OverlordRush
am i just stupid or is there not a skip to next album option with the AK OS... still trying to get use to it...
A friend of mine (who has a lot of headphones) has the dt1770 as his work closed back and swears by itFolks,
Thanks for all your Kann Cube alternatives and if there are no other suggestions, I think I will go for...Kann Cube
Now.... I need your recommendation for closed back cans below 2k that will become a perfect combo with the new Kann. I like organic sound, almost flat frequency response with slight V shape (but not too warm and not too bright). Mid-bass boost or rolled off high frequencies / low frequency bass is also not something what I'm looking for. I want details (macro and micro), soundstage and quality, I want to feel the music without it being too warm or too bright or analytical or lifeless. Alternatively just say what you have and the sound characteristics when paired with Kann Cube.
Thank you!
M.
Thats all to complex for me lol, but I quite like the Focal Elegias as closed back HPs.
Leakage is ok but have listened them?How's the sound leakage on Elegias? Do you think they could be used on a train without disturbing others, and what about the size?
Hi maxwillis, how did the mmcx break? was it the housing of the Shure, are they plastic like the 535, or was it the metal connector somehow? any photos?
are they new? any chance of warranty?
thanks
nicodem, what did you find bad about them? I found them good and better after burn in of about 50 hours or so. I don’t have the volume very high and no ones complained about leakage as expected I guess
Very soory to hearMy MMCX end broke in the shure se846; I was trying to upgrade the cable. What a bummer! Maybe, i'll skip the whole commuting with cube for now; another iem is out of budget at the moment. However, I'm also interested in knowing good alternatives to se846 for commuting, including on the ear headphones. Seems like the MMCX is a really bad idea - very fragile and prone to breaking, specially on equipment costing this much.
