So far I can't find any detailed specs, has anyone found published confirmation on the following:
Headphone Jack size/type?
We know it is a single DAC, but does the amp section offer a balanced signal?
If the above is SE and not balanced, what happens when docked with PM13??? is it an SE signal on XLR jack or is it a true balanced signal output?
....and is there a difference between the signal put out through the headphone jack and the signal that goes into the docking station/cradle?
Also, thanks to those above that responded to my earlier post. I do have the Dragonfly 1.0 and 1.2 and a Samsung Note 4, but have not used the latter for music playback as of yet. I am still searching and can't find any reference to quality of signal coming out of PM13 dock via XLR cables... I am very curious to find some feedback on how the AK300/320/380 in the dock would compare to a high end USB DAC.
The main Astell & Kern site has the specifications for the AK300 posted. Can't post a direct link due to their script-driven navigation (no direct URL to the page), but the "Specification" link is to the right of the page at the top once you are on the AK300's product page.
Those specifications say that the connections are a standard 3.5mm TRS (single-ended connection) and a 2.5mm TRRS (balanced) connection. They have the "typical" output specifications for AK players since, well, they started shipping the AK100ii.
Can't comment on how the 300 series sound via the dock, but I found a Mojo driven off their optical connection sounds better than any of them through their headphone stage.
