To me yes, I found the presentation a bit too flat until I turned it on.
Similar to HQPlayer upsampling where it also opens up the presentation
Thanks for the response, any plans to add this functionality?
Interesting, can’t really understand why you’d want more screen real estate being used. The buttons work well for faster navigation though, so I guess there’s that. Not a big deal overall but it’s a little annoying for me. It squishes the Spotify UI and it doesn’t look too impressive.
DSD or PCM ?Basically! I am going back and forth toggling it on and off. With it off it sounds like the music is being restrained by physical borders. With it turned on the entire presentation has more room to breathe.
DSD or PCM ?
Anybody know what class amplification is being used? Is it A, A/B or D? A&K don’t say.DSD or PCM ?
Although my files on sd card are upsampled to 16fs pcm with PGGB, I prefer the DSD DAR for the streamed files. Great feature. I also like the double tap wakeup. I wish you could have the screen always on when playing with a charger attached.I couldn’t really tell a difference between both, but I just stuck it on DSD![]()
ThanksSP2000 is definitely Class A on based how warm it gets when playing music. SP3000 is definitely Class A as well
Had both for a couple of days before shipping SP2000T off to a new owner. SP3K is indeed a worthy upgrade in both SQ and usability in my opinion. SP3K sound quality is a wholesale improvement to my ears. I thought SP2KT sounded veiled and flat in both SS or tube modes by comparison.Wonder if it's worthy to upgrade my 2000T to SP3000? anyone listen to both have 2 cents?
Mine has arrived, this is my first A&K DAPs, I can't seem to find gain setting, where is the setting to set the gain level low, medium or high?
Oh I see, this is my first time having a DAP without gain setting. Thank you for the confirmation.No gain setting with SP3000. That's only with the Kann line IIRC
