Quicken
- May 12, 2005
I'm running MM 2.5.4.978, and have the latest kernel streaming plugin (3.6) running (along with resampling to 24/96). Works OK for me, although the resampler puts a bit of a strain on my system (typically 15 to 20 % CPU). Are you sure your card is set to receive the input rate your kernel streamer is sending it? If there is a miss-match it will behave as you described.
Cheers,
Q
Cheers,
Q
