Stock cabel on RH is First Times cabel, not Attila, Attila is on FS version, correct me if i am wrong.I have Attila on RH and i tried with Aroma and is much better than the original cable
Midbass and mid more natural and fuller
Aroma audio product impressions.
- Thread starter audionewbi
Doug2507
Attila on RH FE (Indigo type shell), FT on the other.Stock cabel on RH is First Times cabel, not Attila, Attila is on FS version, correct me if i am wrong.
klyzon
- Jan 17, 2012
Anyone using the Jewel on wm1zm2? I feel like the Jewel needs more power and I'm not sure if the wm1zm2 will be a good pairing with the Jewel
I agree I think you need more powerAnyone using the Jewel on wm1zm2? I feel like the Jewel needs more power and I'm not sure if the wm1zm2 will be a good pairing with the Jewel
I prefer Jewel with WM1ZM2 than N8ii. Power is more than fine. Sounds excellent.Anyone using the Jewel on wm1zm2? I feel like the Jewel needs more power and I'm not sure if the wm1zm2 will be a good pairing with the Jewel
Xinlisupreme
@audio123Anyone using the Jewel on wm1zm2? I feel like the Jewel needs more power and I'm not sure if the wm1zm2 will be a good pairing with the Jewel
Hi guys. Sorry to intrude with a question, maybe someone heard Jewel on P6 pro black? I wonder if there is synergy, or will I have to buy the N8-ii as well
Xinlisupreme
Some people love Jewel with LP, some With Cayin, som with Shanling, I think depends on music preferences and taste.
I tested Jewel with N6ii ti and RS6 only, and o preferred N8ii brother.
N8ii would be meatier than N6ii Ti so on paper would match well but with P6 Pro and M9 also.
If you own P6 Pro try with it before let it go.
One more question, how is ACE compared to Jewel? I choose between these two models.Some people love Jewel with LP, some With Cayin, som with Shanling, I think depends on music preferences and taste.
Xinlisupreme
Both are real TOTL IEMs, but still very different.One more question, how is ACE compared to Jewel? I choose between these two models.
Speaking on bass performances Jewel is more oriented on sub bass and has less midbass compared to Ace.
Jewel is more transparent on mids/high where Ace is meatier and smoother, both scale a lot with better cable.
Jewel detail retrival is crazy, Ace is very good but more relaxed, I found Ace something between Jewel and Trailli mids.
I love Ace with copper+ and Jewel with TriHybrid (PlusSound cables).
Jewel is more demanding and maybe sounded a bit intimate instead of Ace that has bigger stage.
Ace is the best full BA design ever heard and I listen it in “Ace mode” (switches balanced mode) i nerved found it BAish at all and bass is good enough for me, but depends on your music preferences.
Thank you,It was very well explained!Both are real TOTL IEMs, but still very different.
Xinlisupreme
Let me know what will you choseThank you,It was very well explained!
Sure!Let me know what will you chose
Scubadevils
- Nov 18, 2011
Some people love it with LPGT
Xinlisupreme
OFC Bro, sorry I forgot Lotoo and Sony also, WM1Z-M2 would be another great choice for Jewel
There are so many great daps
