cactus_farmer
- Feb 12, 2008
I've read numerous reports of the 'grattle' (Grado rattle) that happens when Grado cans have one (or both) of the membranes of their drivers creased and wrinkled in places - causing rattling on low bass notes and channel imbalance. Does this creasing and wrinkling occur only when the cans are blasted at monstrous levels, or does it happen even at just higher-than-average listening volumes?
How loud do you have to drive your cans in order to actually damage them, and is it likely that anyone with normal hearing would listen at that level normally without knowing he/she was damaging their headphones?
