kkugel
Member of the Trade: IEM Maker
My listening tests above, try the song!Could you elaborate please? Source?
How you hooking it up? Over AirPlay or turning on Spatial will both output at 256k aac. And Spatial does all other kinds of things to the music. Most are saying only sounds good on recent releases. I think only benefits cheap close headphone. But people saying if use camera adapter and a dac, Apple Music is true to the source. Apple even says need direct connection.My listening tests above, try the song!
How are you listening? I tried headphone out on a M1 macbook and a dac, both distorted my planars like crazyhmm - I have spatial turned off and lossless on (not hi res lossless). "The Imperial Suite" from the Star Wars Rogue One sounds the same to me as the FLAC I have from the CD.
No spatial, direct on laptop out. WeirdHow you hooking it up? Over AirPlay or turning on Spatial will both output at 256k aac. And Spatial does all other kinds of things to the music. Most are saying only sounds good on recent releases. I think only benefits cheap close headphone. But people saying if use camera adapter and a dac, Apple Music is true to the source. Apple even says need direct connection.
I just tried this track on my M1 MacBook Air. I tried the following methods with Focal Celestee (don't have planars with me atm):How are you listening? I tried headphone out on a M1 macbook and a dac, both distorted my planars like crazy
Honestly, for what it’s worth, I’m impressed and am hovering over saying it’s superior. Apple have always had amazing source as they’ve been able to hang for so long using just AAC. I’ve dropped tidal in favour.How does the lossless on AM compared to Qobuz, Tidal, Deezer, etc? Just curious
Yes, my DAC works perfectly on my phone and other computerI just tried this track on my M1 MacBook Air. I tried the following methods with Focal Celestee (don't have planars with me atm):
Are you sure you have enough power to drive the planars you are using?
- Old school AAC (lossless not enabled) on MacBook 3.5 jack = no bass distortion detected
- lossless to headphones on MacBook 3.5 jack (Audio MIDI can't be matched as the headphone jack is locked to 32 bit float) = no bass distortion detected
- lossless to DX300 in USB DAC mode with Audio MIDI matched to the track (24/44.1) = no bass distortion detected
- Qobuz to DX300 in USB DAC mode exclusive mode = I was unable to detect a difference between this and AM lossless
Must be that Swiss internet then.Yes, my DAC works perfectly on my phone and other computer
To be honest, I couldn’t even tell any difference between regular Apple Music AAC and Tidal in the past if comparing 1:1 the same track, same source. It has been that good for years. And now with lossless / High-Res I have the good feeling of getting 100% the best possible material. No need for anything else for me too!Honestly, for what it’s worth, I’m impressed and am hovering over saying it’s superior. Apple have always had amazing source as they’ve been able to hang for so long using just AAC. I’ve dropped tidal in favour.
Spatial is working as intended, lossless Atmos requires a blu-ray or very advanced AVR and TV and streaming sources that don't yet exist.How you hooking it up? Over AirPlay or turning on Spatial will both output at 256k aac. And Spatial does all other kinds of things to the music. Most are saying only sounds good on recent releases. I think only benefits cheap close headphone. But people saying if use camera adapter and a dac, Apple Music is true to the source. Apple even says need direct connection.
