Jan 11, 2018 at 3:19 PM Post #16 of 33
Just a quick update.... had a complete cable made with the Westone connectors from effect audio (stupidly thinking they were the same ones that come on the westone bluetooth cable), it looked and sounded fantastic, the connectors wouldn’t stay in properly as they have a recessed part at the male plug. When i was trying to fix this, and completely mangled one of the connectors.
I’ve got a pair of the Shure connectors from effect audio now and this weekend will have put it all together. I’ll post pictures when complete.
Jan 20, 2018 at 8:29 AM Post #17 of 33
Jan 20, 2018 at 12:11 PM Post #19 of 33
Haha thanks, it took me about 5 goes to get it right over a few months, means I can demote the westone bluetooth cable to a gym only cable and I can use this as my on the go cable.
Thank you very much sir for the inspiration!
Mar 20, 2018 at 4:15 AM Post #20 of 33
Here's my take on mine, I cut my beats X and I solder some cheap chinese MMCX cable (black would have the right option but I don't have in hand right now). I could not bother soldering a MMCX plug but I might do that in the future with my second beats X. Not pretty but it'll get the job done. Powering my iBasso IT01 and Westone UM Pro 50 v2. Sounds good than a lot of my MMCX bluetooth cables.
Mar 26, 2018 at 6:02 AM Post #24 of 33
One thing for sure, after extensive comparison between wired and using the beats X mod I noticed loss in the sub-bass and treble on both of my IEMs (iBasso IT01 and UMPro50) no idea if this is because the MMCX plug not connected directly to the beats x wire cable or simply the built in amp not capable of pushing the said IEMs. Would like to hear others if there is a noticeable sound difference in your beats x mod compared to wired. So far my PLUSSOUND mmcx bluetooth cable and my cheap Sony SBH20 adapter are the only bluetooth adapters that sounds close to wired but they really suck at providing decent and stable bluetooth connection especially when used in the subway.
Mar 26, 2018 at 7:27 AM Post #25 of 33
I guess it must be an issue with the resistance vs the power of the cable. I have the westone Bluetooth cable, and the beats mod, I think the beats mod sounds better, but I think the only difference maybe the volume output being a bit higher.
I have a double helix cables symbiote sp 8 core and there is no competition between the two, I like the Bluetooth for simplicity, but I would never consider the sound to be in the same league as the wired option.
Mar 27, 2018 at 12:28 AM Post #26 of 33
Well, I had another try so I desolder the copper MMCX and soldered a decent one cut from the Magaosi cable from my already sold K3 Pro and this time it sounded really good, almost a close as wired. I will still do the MMCX soldered directly to the beats x wire. The reason why I want that short wire is I feel like the beats X cable is not long enough for the mic remote to reach my mouth during calls.
Mar 27, 2018 at 6:53 AM Post #27 of 33
I have mine quite short, it hasn’t had any effect on the call quality if I’m being honest.
I prefer the shorter cable as I find that when its longer it just wants to flap in to my face haha
Oct 15, 2018 at 10:35 AM Post #30 of 33
When you replaced the phones on your Beats X with connectors did you run into any trouble? I just opened mine up and can't seem to get any signal on the multimeter regardless of which pair of wires I test. On either end I have the following wire combos:
Red (coated)
blue
red/green
brown
Green (Coated)
I'm guessing that Red/blue is Right/Right ground and Green/Brown is Left/Left ground and the striped wire is the mic connection? It's strange to me that they would wire left and right to both sides of the headphones. Regardless I'm wondering if I messed something up as I can't seem to get a signal out of any pair.
