Has anyone tried the new SpinFit CP1025's for their APP's?
Apple AirPods Pro And NEW AirPods Pro 2nd Gen (from 23 Sep 2022) - Impressions
- Thread starter angelom
soas
I have been a champion of Xelastecs on my IEMs but unfortunately they are difficult to recommend for the APP.
My OEM silicone tip sizes are S in my left ear, and M in my right. I bought the two small and medium variety packs, and found MS to work the best. However, the bass is reduced, and my suspicion is due to their design. In comparison, the Apple ear tip cores are soft, taper inwards, and go further into my ear canals.
The Xelastecs use a much wider hard plastic base, which attaches to the APPs themselves. The TPE ear tips then attach to the hard plastic. Maybe these would work slightly better if you have cavernous ear canals. I do not.
Tried everything from the SS to ML sizes; they all result in shallower insertion. Bass, mids, and treble are all slightly recessed, though most notably the bass rumble and impact. The tips end up being great for things like podcasts, music with less bass, and exercise as they simply do not budge. You can yawn, move around, talk, eat, and they do not feel like they might fall out, even hours later.
stephenlee2801
That's a shame to hear, Xelastecs was one of the options I was looking to solve my issues with the stock ear tips. At the moment I'm in between sizes with the stock eartips so the seal isn't as good as I'd like. Currently looking for an alternative...
I’ve ordered the spinfits. Will let you guys know how they are when they arrive
I got my APPs a few days ago, and so far I'm impressed. The sound is pretty good if I get the orientation right. I'm looking forward to the new capabilities that will come with iOS 14. But a question - this is my first pair of IEMs with ambient mode. How much should I be hearing from the "outside"? Do I need to point my head at someone when they're talking for it to come through?
angelom
- Apr 19, 2015
Ambient mode is the same like when you aren't using IEMs and you having nothing in your ears, so you can hearing everything, all the sounds from all the directions. You don't needing doing nothing more except activating this excellent feature.
For some reason I can't hear much when music is playing. Is it only when it's paused? Or is my music too loud?Ambient mode is the same like when you aren't using IEMs and you having nothing in your ears, so you can hearing everything, all the sounds from all the directions. You don't needing doing nothing more except activating this excellent feature.
soas
Music is too loud. Transparency mode doesn’t compensate for volume.
Thanks for the help! With all the features and seamless integration, these can't be beat. If they include EQ in the new OS, they'll be great.Music is too loud. Transparency mode doesn’t compensate for volume.
Dobrescu George
Reviewer: AudiophileHeaven
I made a video review about it, with a lot of honest, critique, and many in-depth impressions about them. What works if you're on Android, and what doesn't and how do they sound?! All in the video review
soas
Any impressions yet, hopefully?
APPs are my most commonly used headphones, but also my most temperamental/ill-fitting pair. Hoping for that magic bullet someday with great retention and sound quality.
Not yet, unfortunately. The tips are in transit and due to arrive early next weekAny impressions yet, hopefully?
Just received the Spinfit tips for the AirPods Pro.
Initial sound impression is they make the APP sound cleaner - mid is clearer and better treble compared to the stock tips. Comfort is also better with much lesser pressure point on ears. Still need to give them a bit more time.
Fit into the case without any problem too.
Additional impressions of the Spinfit CP1025:
- Bass is similar to stock tips in quantity and quality (make sure right size tips and good seal). Bass will go low to sub bass region but still lack punch which is normal and within the limit of the APP driver.
- Passive sound isolation is similar, which is medium isolation level to me
- Sound quality is not affected by either ANC on or off
Total: 6 (members: 0, guests: 6)
