tiagoncalves
- Mar 26, 2012
Thank you both for the explanation about the decoupling and bypass caps. So, if I understand, I'll put one ceramic cap (100 pF) between the V+ and V- of the both OPA2132 in the left and right channels.
I tried to draw a layout for this amp, assembled in a perf-board similar to the one I post above:
In the software I used, it didn't have a board template like the one I'll be using, so I had to draw the paths. I hope it's understandable.
I tried to make a ground circuit like what I think is a star grounding. Is it right? And I'll solder the small ceramic caps under the OPA2132, to have them right close to the chip.
If someone have some suggestions, I thank in advance!
