chych
The butter knife's second victim.
- Jun 21, 2001
I use a "Dutch Boy" 60/40 rosin core lead free (??) solder, you might want to check that out... I have no idea why you do not want silver in your solder, that is a good thing. The WBT 4% silver solder melts at relatively low temperatures so you will get a nice easy well made joint with it.
I don't think there are any good right angled miniplugs out there, so you are stuck with 180º ones.
And you are sort of supposed to use a heat gun for heatshrink. A hair dryer will NOT do, a ceramic heater barely passes. A soldering iron is overkill and gets the heatshrink messy (but boy does it SHRINK it).
Now, since there are no giant miniplugs out there, you are going to have some diffuculty making your cable. I used teflon cat5 in a dual kimber pbj style configuration and it all fit nicely. You may have to ditch the barrel of the miniplug, solder the connections (it is VERY hard to do this if you are using big cable on a miniplug), cover the whole thing in teflon tape or electrical tape, heatshrink to make it look nice, and keep it that way.
...Or just not use the BL-1 cable... which is silver plated copper anyway and can get some brightness in your sound, which may seem more detailed (I've never heard it so take this with a grain of salt)... And I'm not sure why you are inclined on going for the DHLab RCA either, I doubt they are better than Cardas/WBT.
