Any volume limitation hack for SONY NWZ-A816 ?
Apr 19, 2008 at 7:43 PM Thread Starter Post #1 of 58
veracocha
This player sounds great ! but not as loud as cowon's any volume limitation hack for A816 ?
Apr 19, 2008 at 9:41 PM Post #2 of 58
are you saying you are already using the player at max volume already? are you using high impedance phone with your sony?
i suppose the cowon can go higher because it has a higher stock power outpout than the sony
Apr 19, 2008 at 9:55 PM Post #3 of 58
What headphones are ya using ?.I've got the same player and cant go above 18 with MDR-EX90's and 13 with Super.5's
Apr 19, 2008 at 10:40 PM Post #4 of 58
There is no hack for the player,its 5x5 watts output,and is perfectly loud enough
As stated it sounds like its the headphones you are using that's the problem
I dont need to have mine louder than 15 with either philips 9600 or k81dj
It's plenty loud enough!
Apr 20, 2008 at 8:22 AM Post #6 of 58
okay, the cx-500 is only 16ohm, so that shouldn't be a problem since i only listen at around 12 or so with my 25ohm UM1.
are you getting a good seal? these phones works the best when you block out background noises. try using a bigger sleeves that came with the package.
lastly your device (phone or sony) may be defective
Apr 20, 2008 at 8:35 AM Post #7 of 58
no problem for device , the earphones getting seal perfectly in my ears , the problem is not loud for bassy music like trance ,techno ...
Apr 20, 2008 at 8:46 AM Post #8 of 58
do you experience the same problem with all of your songs? or only a few. could it be that track is actually encoded such that the entire song is softer by some number of dB?
the problem is only with bassy music like trance, techno?
can you hear the bass for hip-hop/rap fine?
Apr 20, 2008 at 1:46 PM Post #9 of 58
something must be wrong in this case..
are you using MAX volume with your sony? does it have volume settings, like high or normal? have you got your hearing checked(im serious)?
Apr 20, 2008 at 2:06 PM Post #10 of 58
that is pretty interesting...I usually can't go past like 18 with my setup
Apr 20, 2008 at 5:55 PM Post #12 of 58
Either you're going deaf, or you have a fault MP3 player, let's hope for your sake it's the latter, it's definitely not normal to have to turn the volume to max using cx500's, even with an MP3 player that doesn't have very powerful output. Your music could have a really low volume, but that would be pretty odd for that to happen without you purposely doing it.
Apr 20, 2008 at 6:14 PM Post #13 of 58
buy a portable amp =)
Apr 20, 2008 at 6:18 PM Post #14 of 58
I'm just a headbanger
Apr 20, 2008 at 9:01 PM Post #15 of 58
I think the music might just be encoded with a low level of volume.
That or you are going deaf, and you seriously need to watch your volume.
I'm using an A818 and CX300s, and I barely go past 10/30 on the volume scale.
