Voodoochile
Supafly & The Funky Pimps
- Sep 13, 2002
If you just retract the plug from the jack normally, there is no problem. If you were to stop partway in or out (shorting) then that would be different. I actually prefer not to use the locking jacks for the reason that if anything, removing a plug from one of those takes a bit longer than from a normal jack.
Don't forget that it also has to be isolated from the chassis, so stock selection is limited. You can isolate a regular jack as well if needed.
Someone around here disassembled the locking Neutrik and modded the tension spring for the latch (was ist los or doobooloo maybe?), which seems like a reasonable thing to do.
