ProtegeManiac
Yes, I fully understand that the main thing about a system is the headset, and I did this test that you said and I could not distinguish the difference between the two, but explain one thing to me, if the amplifier only has the function of amplifying the So what are the advantages of having more expensive amplifiers besides of course the power they offer?
Lower noise and distortion, ie, they amplify the sound without modifying or adding to the signal. The more they have to amplify the signal (ie the higher the output), the more likely the circuit will add either, so you have to design that circuit to mitigate that. With pure Class A amplifiers they're avoiding the crossover distortion that happens when a Class A/B amplifier switches over to Class B. Some Class A/B amps have a higher Class A bias so you'd really have to crank them up with hard to drive headphones to start getting any of that. Class D amps don't have crossover distortion but so far the technology has more distortion and noise on high impedance loads at higher frequencies, same way that when these first came out they had a lot of distortion and noise at higher frequencies even with lower impedance loads, which is why they started out as subwoofer amplifiers or high power PA amplifiers (though these might still be using Class G or whatever) where low distortion and noise aren't as critical.
