eragon1307
- Jun 10, 2015
Must be at least a year now. No plans to upgrade any time soon, if anything, perhaps an external DAC as I'm getting a little noise coming from my soundcard at really high volumes - nothing major though. Definitely no plans to upgrade the amp (Asgard) anytime soon as it's more powerful than anything I would ever need for headphones. That, and I love the look of it.
In terms of sound quality, I do believe I get a little more bass (perhaps cleaner bass*?) with the amp vs no amp with the K712s. It's hard to describe, but I do feel a difference there. It also most definitely can get louder with the amp (obviously ).
Great. Now I think I will stick with K712 and Asgard 2 . Thanks so much.
Oh, you would love the Asgard 2. Don't worry about getting the Lyr.
Now if you are still thinking about the Lyr 2, in the same price range, you should consider the Meier Corda Jazz: http://www.meier-audio.homepage.t-online.de/jazz.htm
If you say so, then Asgard is enough for me. Thanks for your help from the beginning
How about the DAC ? Should I keep the DACMagic 100 ( 155 Euro, new) or buy an secondhand Bifrost ( USB, no Uber, about 280 Euro) ?
