Gbjerke
- Feb 5, 2009
Well, as in all cases, when you have something good already, youre gonna have to pay alot to get it better. Speaking of a stereo system
u can get one for 200$ decent,
and you can get one for 200 000$, and that stereo system isnt 1000 times better. If ur looking into the ie6, which is an iem, meaning that you dont get so much difference from an amp, I'd probably maybe get the IE-8, drop the amp. I use an amp since my headphones are big, even my portable ones. I dont like IEMs, never have, get better comfort and less pain with big ones. If you're worried that it wont be worth it, buy something alot cheaper, or dont and wait some time until you feel like having an upgrade. You see people here buying the D10 and using it with IEMS, and IMHO that really isnt worth the cash. The good thing about the P3+ is that you can have it forever change opamps and if you take care of it, it will last for a very long time.
So, i guess what im saying is, if you have big cans, an amp is worth it in the 200, 300$ range. And even with an IEM, SOME people will find it worth it as they just want perfection.
Though..I would get some good headphones/IEMS, before getting an amp. Meaning that, the IE-8 will sound better than the IE6 with an amp. The whole audio businnes is very exaggerated. My P3+ gives me that bit of ..cant describe it, that last part of ..woah! factor you know. But I'm sure that something higher in the ranges of the IE-6 will get you some serious WOAH!
If you though, really ever decide that, I want an amp! The P3+ is extreme bang for the buck.
