Oh Ok cool. Also, on the Amb instructions, when testing the opamps it says:
"Use your multimeter and check the resistance between each pin of the opamp and the pad to make sure you don't have a cold solder joint (i.e., your meter should read close to zero ohms). Also check continuity between adjacent pins for solder bridges (meter should read infinity). "
What does it mean by the "pad"? Also, I think I know which settings I need to set my multimeter to check resistance, but how about for continuity? Same settings? Still ohms? Is it possible to somehow damage the opamps while trying to test them? Sorry, I'm a huge noob.
Again, thanks for the much needed help, amb.
