I have half a dozen or so old school analog headphones I’d like to be able to use with my new (to me) iPhone 14 Pro Max. Apple does sell a cheap Lightning to 3.5 mm adapter but it’s…well, cheap. The dongle has an on board DAC (as per Apple’s product description) that’s pretty craptastic. Is there an alternative to this adapter other than Bluetooth? I’ve tried Bluetooth headphones over the years and audio quality and user experience has always been pretty crappy. It’s gotten incrementally better over the years, but still subpar compared to wired options.
There are any number of dongle DAC/amps available at all manner of price points, most would come with a lightning to USB-C cable for iPhone use.
However, you seem to be convinced that the Apple dongle is rubbish and there is no point even trying one. I think that is incorrect.
I might not have audiophile golden ears but I have compared an Apple dongle against some pretty decent portable equipment that cost between 10 and over 100 times the retail price of an Apple dongle. I was using several pretty decent IEM, some that needed a decent amount of power to get appropriate volume.
I wanted my fancy gear to wipe the floor with the Apple dongle but that was not the case. If there were any differences in my casual listening comparisons they were a very long way from obvious.
The Apple dongle gets a lot of criticism mainly from folks that buy into the nonsense that surrounds this hobby. Why wouldn’t Apple be able to make a good little dongle at a cost effective price ? They have massive R and D resources and a budget that is probably bigger than all the audio brands combined.
If you want to try others that is entirely understandable. I can’t recommend any specifically because there a dozens of options and I only have a couple.
I would, however, definitely recommend starting with an Apple dongle or, if you want to spend a bit more money, a ddhifi TC35i simply because of the convenience of not having a cable to bother about.
