drewd
Banned
- Apr 26, 2004
S1 and S2 are for the switch.
V+ and GND are the inputs. The amplifier runs on a single voltage, so there is no V+ and V-, only V+ and ground. You do need to orient the LED correctly - there is a flat spot on the silk screen symbol. That marks the cathode, or the "negative" side of the LED. That would correspond to the flat side of the LED and also to the short leg.
-Drew
Originally Posted by shut85 i've gotten all the parts on the board except for the components like the power and inputs and outputs, i assume that s1 and s2 are for the switch but i only see a v_in pad and was wasnt sure how to connect the power exactly. wouldnt there be a v+ and a v- from the power to connect to the board, so where would the two go? also is there a certain way i have to orient the led on the pads next to d2la, like is there a + side and a - side? |
-Drew
