rreynol
- Feb 1, 2005
Multimeter should be on DC volts and I'd imagine that the amp should be on (why would there be current flowing with it off? if it is, you may have another problem). Do you have the tubes plugged in? When I first put mine together, I had a 'duh' moment and couldnt figure out why the trimpots had no effect on the tp voltages. Then I realized that I was dumb and plugged the tubes in. Also, I noticed that you really don't see the voltage changing much until the trim pot gets to a lower half the of the range. Hope that helps. If not, someone else will probably have some suggestions. I, too, am a tube noob.
Originally Posted by JWFokker The trim pots don't seem to make any difference when I adjust them. Maybe I'm not measuring the bias correctly? What should I have the multimeter set to when I measure it, and should the amp be on? I previously measured the bias when it was off and got reasonable numbers, but the trim pots don't change anything. When I tried measuring it when it was on, I didn't even get a measurement. |
