Gino
- Apr 2, 2003
Hot glue is fine. If used sparingly, it will be easy enough remove.
My cable broke tonight to my dismay. Small cracks developed on the insulator near the plug strain relief. As a temporary remedy, I applied clear epoxy around the area. It works fine now.
I am now looking to recable my IM716. My iPod Touch buds seems to have the right size and color cable to replace the plug to pod segment. The cables running to the buds are very thin. Looks like I may have to look for cheap buds with white cables.
