"Alps" stepped attenuators pin order
Jan 25, 2007 at 7:34 AM Thread Starter Post #1 of 7
Yen
Hi!
I bought some of these infamous fake "Alps" stepped attenuators from Hong Kong. They have the fourth pin, so what are they for? Loudness?
Are the pins otherwise same as normal pots?
Thanx.
Jan 25, 2007 at 9:21 AM Post #3 of 7
That's what the consensus has said in the past.
Yes.
Jan 25, 2007 at 5:34 PM Post #4 of 7
Thanx Tangent. Successfully changed to my SOHA.
My last cheapo pot was a total crap. It was like usual stereo tests...
Jumped from one channel to the other.
Jan 25, 2007 at 10:30 PM Post #5 of 7
This thing is definately worth its money. No cracks or any sound when changing steps.
However, I notice that outside the listening range (from 12 o'clock and more) this thing hums like hell and gets louder every step. In the listening range, there is no hum or anything, total silence. It isnt a problem, since I will never go over 11 o'clock, but is quite strange. I did not ground the case of the pot, should I?
Jan 25, 2007 at 10:48 PM Post #7 of 7
Yes, you should ground the case of the pot. If you don't want to chassis ground it, you can loop a grounded wire under one of the screws on the back.
