- Dec 30, 2013
omastic: Yes, very comfortable and high bang for your buck with this one. Keep your eyes peeled for LMUE's announcement, guys!
Any news about the newcoming replacement cable with mic? or any other third party compatible cable with mic...
thanks
Hi, just picked up a pair of these and am very happy with the sound. Found they needed a decent amount of EQ'ing within Neutron to bring out low mids of vocals, and I think I rolled back 250Hz, but bass is amazing right down to the bottom. Using foam tips after experimenting with everything provided. (Non upgraded cable)
Can any of you tell me how much benefit I would see from using a DAC/AMP with these headphones or just a DAC? I am running straight out of Nexus 5 at the moment. Volume is maxed but acceptable. Would something like Dragonfly/Fiio help or are these IEM's kind of the limiting factor in improving the sound? Thanks for your help.
Mike
What size Comply tips are compatible with these?
@Hisoundfi: Thanks for the review!
@ekimwons: I can't comment specifically on AD01 until I get them back from @Hisoundfi, but I will say that I generally find that I hear an audible improvement from using a dedicated DAP or Amp/DAC vs. my iPhone 5s when volume matched. YMMV, but that's my experience. @omastic and I are both members of TEAM FLC, so there's respect. However, I wouldn't recommend Astrapi, finding it a quite "exaggerated" sound signature. I can see where some might like it, but for me it just didn't sound natural and sounded off with some of my BA IEM. That said, I found Cozoy Aegis (next step up) to be quite spectacular as far as sound is concerned.
