meomap
Make sure to spend some money to upgrade the tubes in Studio Six.Black SS, silver phono?
Did anyone get JAN Philips 0B2 with theirs? I’m wondering if they should be replaced or it won’t make a huge difference. Thank you.
I tried searching but I couldn’t find a definitive answer. Does anyone know if I can use 6SL7GT in the 6SN7 slot? Thanks.
I believe there was a brief mention of the 6SL7 on this thread before, not exactly the 6SL7GT but should be within the same range.
https://www.head-fi.org/threads/alo...s-and-impressions-thread.674498/post-11827699
I just recently had the same issue but it turned out, in my case, to be the 6SN7 tube KENRAD I purchased used on eBay two years ago, replaced with the stock tube and the issue went away; now waiting for the RCA Black plate to be delivered as replacement of the current stock one.Has anyone with the Alo phono experienced channel imbalance or anyone who might be able to shed some light on this?
My L channel is louder than my R. I’ve tried the following but no luck:
- Tried 2 different phonos and they were fine so I know it’s not the turntable
- Switched the left/right 12AUX tubes
- Tried a different 6SN7 tube
- Tried different cables
On my amp with channel balance knob, I had to turn it to 3 o’clock in order to center the sound.
Thanks in advance.
Thanks in advance.
Hello Njychen.
I am sorry to hear of your phono stage issues.
Let me first compliment you: you have done all the logical things to verify that the imbalance you experience is not within other gear, nor the result of a tube failure in your Studio-Six phono preamp.
I have a couple quick questions for you:
(1) Have you indeed purchased your phono preamp new from ALO?
(2) did the phono preamp arrive with this problem, or did the unit work properly at first and then begin later to show the imbalance?
Either way, the fault is almost certainly within the phono stage, and not any fault of yours.
I'm going to contact Ken at ALO right now, and appraise him of your problem.
If indeed your phono preamp was purchased new from ALO, then the obvious course is to coordinate with ALO, and return ship the phono unit for inspection and repair at no expense to you.
Let me apologize for your inconvenience. ALO is quite diligent in inspecting and testing all units before shipment, but alas, *very infrequently* a piece of equipment will nonetheless require repair.
Thanks in advance, for your patience and kind understanding
--Thomas
Hi Tom,
Thanks for your response.
1) The unit was purchased brand new from a reputable and authorized seller as far as I know. Can PM you the name if needed.
2) The unit has this issue out of the box.
I suppose it’s also possible that both the stock 6SN7 and the other 6SN7 which I bought off eBay may be defective though chances are slim. I will try a 3rd 6SN7 to confirm.
Thank you.
