ramachandra
- Jan 5, 2012
"Put the original capacitors back on but the humm does not go away so now i am wondering what is the problem!?" Once happened with me. I had to scratch off the green film from a wider area for the two 10000uF capacitors to have a bigger surface to solder. Lets hope I'm not wrong and the caps you got fine, Check the capacitance and ESR if you can.
"ps. on the z5500 unit. all the satellites play loud and clear. just hardly any sub. very subtle bass" So it is only the Sub not the whole system. Two OpAmps and two TDA Amp belong to the Sub, if one of the 4 components are not functioning the result is what you experience.
