I would assume that the HE6 blows the HE560 out of the water (on HPA5000)
HPA5000 I suggest. A very impressive animal !
I'm not so sure about that. Based on my experience with HE-6, it requires a tremendous amount of power before it shows what it's capable of. Looking at the HPA-5000's specs, it barely has enough juice to drive the HE-6 to make it sing. That is why I've had much better results with high-end speaker amps than headphone amps of the same price. I'm willing to bet that the HE-560 will sound better than the HE-6 on the HPA-5000.
this is true
and i was about to add.
the HPA 5000 and HE-6 combo is very good. and the HE-6 is the better headphone, tonally, and transparently. despite only having 5W, the HPA 5000 has no trouble with HE-6, it doesn't have the headroom a speaker amp will, but its a good pairing.
on other amps such as the WA5, the HE-6 also outperforms the HE-560.
I'm cleaning out all my gears, including my prized HPA-3000 amp. For those of you interested, here you go.
http://www.head-fi.org/t/732677/price-drop-allnic-hpa-3000-in-mint-condition
I see on the FS pictures that you also have the SMYTH system ! Do you use it often ? is it really for serious audiophile listening or just for fun ?
thanks
I use it all the time, for serious audiophile listening. I wouldn't spend $3K just for cheap thrill and kicks. There are many products, both hardware and software, that claim to do reproduce the 3D holographic sound of a speaker listening environment, but most of them are utter crap and severely compromise the sound quality... the Realiser is one of very few, if not the only (and surely the best) method there is out there that is capable of doing so.
However, there are still some trade-offs, which are not insignificant and for some could be a deal-breaker. The processing of sound by Realiser makes the sound become somewhat less intimate, slower response, and lacking in microdetail. I believe this is caused in part by using HDMI input and optical outputs of the Realiser, both of which are known to introduce a lot of jitter into digital audio. To make up for this, I use a reclocker (the MUTEC MC-3+ Smart Clock) which takes optical input, re-clock the signal to reduce jitter, and output via AES/EBU.
However, the overall change in sound that the Realiser brings is so huge that such differences become meaningless to me. I would say that adding a Realiser to any system drastically levels the playing the field, the differences in sound quality between systems become relatively mitigated by its binaural effect. Of course, that is not to say that headphones and amps become irrelevant when using the Realiser, because you will want to use headphones that are as revealing as possible to hear its full effect. And even if such differences do matter, I've been spoiled by the Realiser too much that I can no longer imagine listening to headphones without it.
very very interesting ! thank you
by the way, since you sold you ALLNIC headphone amp, can you tell us what headphone amp you are using now ? don't you miss the HPA3000 ?
Read my last post above. The amp I'm using now is the ecp audio L-2.
my review of Allnic HPA-5000 if anyones interested
http://headphone.guru/allnic-hpa-5000/
