songmic
Further sonic impressions, now that the amp has been burned in for at least 100 hours...
Again, I have to say that this tube amp is not a warm amp at all, in fact it sounds very clear and neutral that it almost sounds analytic. Yet it possesses the positive traits of a tube amp, the most notable of which is a spacious, airy soundstage.
I was surprised by its performance in driving the HD800 on its high impedance output. Simply put, this is the best amp I've heard with the HD800 to date, better than my previous Bakoon HPA-21, maxed-out ZDSE, or even its bigger and more expensive brother HPA-5000. I have yet to audition GS-X mk2 or ecp L-2, which are supposedly the best amps for HD800. I asked Mr. Park why the less expensive model is better sounding; he explained that the HPA-5000 is optimized for low impedance headphones, while the HPA-3000 is more versatile as it has two outputs (for low and high impedance headphones, respectively). In addition, he stated that the high impedance output (which is supposedly intended for 200 ohms and up) is actually optimized for 300 ohm, and he has used the HD800 to design this particular output. On the other hand, the HE-500 was used to tune the low impedance output, making it ideal at around 30-40 ohms. The HD800 driven on high impedance output sounded more full-bodied, airy, and overall superior sounding to the LCD-X on low impedance output.
I have an HE-560, an updated model over HE-500, inbound home. I'm looking forward to trying this headphone on the low impedance output, and compare it with LCD-X and HD800 using this amp.
