10 days ago I purchased one Odin Gold RCA IC and put it between DAC and preamp. I was still using odin 1 (1.5?) between preamp and active crossover, and between crossover and amps, and the combination sounded fantastic.
I then ordered a complete set of 3 other Gold RCA iCs to replace the "old" Odin 1s and received them a couple days ago. They came from a different vendor and, even tho they share the exact same photos, they are slightly different: the first set has plastic body plugs, these have metal body plugs that seem to be impossible to unscrew.
I'm not enamored with the sound at all. They system now sounds dark with a recessed midrange, vague imaging, bloated bass, splashy treble. I have 15 days to return them and I'm hesitating. It's probably just a lack of burn in - where they are located in the system they don't see much current. I hope things will get really better. It's impossible to see if they built the cable the same way as the first one... the wire is the same, but how is it connected to the plug? I dunno...
