Crypt Keeper
My pleasureI appreciate the pic, patience and sharing.
![Headphone Smile 2 :smile_phones: :smile_phones:](https://cdn.head-fi.org/e/headfi/smile_phones.gif)
Thanks. What is the fo.Q T-102 on the outside of the cap for? And can you show a photo of how that's used?Have been using these types of caps for 20 years. Usually gold plated brass, teflon insulation. No center pin, only ground contact. Idea behind these RCA caps is to minimize RFI through the RCA jacks. I use them with fo.Q T-102 on the outside of the cap. Can hear a slight lowering of noise floor when enough of the RCA jacks are covered. The effect is very slight but to my ears still there.
Totally understood…, except the pink part, I’d see it you said salmon.Thanks for the suggestions.
The problem is space constraints so I'm trying not to go too big. I'm not really concerned with aesthetics, only function, it could be pink for all I care as long as its cheap.
You’re more than welcome.Thanks, I forgot they sold such a thing. Will consider this. First the passive grounding units. I plan to be buying a new home hopefully sooner than later. Use to have dedicated lines, miss those.
This is extremely easy to make.Basically the same grounding RJ45 cable from Afterdark...
https://www.adark.co/products/after...ackice-ground-box?_pos=1&_sid=e43cfb181&_ss=r
See attached pic. Pic is of Lexicon preamp while I was packing it up. Look at the caps, the black round material on the gold plated caps is the fo.Q T-102. I used a leather hole punch to get the fo.Q T-102 round. The fo.Q T-102 is micro vibration control material.Thanks. What is the fo.Q T-102 on the outside of the cap for? And can you show a photo of how that's used?
Kind of what I am planning to try. The router does not have a earth ground. What I am actually going to try is take a CAT 7 cable (OFC copper lead), strip and cut off all the leads except the ground pin lead Entreq uses. Teflon wrap and heat shrink to guarantee no shorts. Other end of lead to grounding box or similar.This is extremely easy to make.
That is a toolless shielded rj45 connector and you could connect it to something like this or a grounding box should offer some improvements.
You can use whatever wire you want. Doesn't have to be a cat anything.Kind of what I am planning to try. The router does not have a earth ground. What I am actually going to try is take a CAT 7 cable (OFC copper lead), strip and cut off all the leads except the ground pin lead Entreq uses. Teflon wrap and heat shrink to guarantee no shorts. Other end of lead to grounding box or similar.
I read from a couple of users of Entreq boxes that upon doing what I want to try was astonished at the performance increase.
I just picked a RJ45 cable because it had 23ga. OFC copper. Pin 4. Can just search the net for "Entreq eartha rj45 cables" and see a few pics of the actual cables.You can use whatever wire you want. Doesn't have to be a cat anything.
Not sure which pinout you would connect that to though? Theres 8 wires in the ethernet cable and it would probably go on the negative but which one ?
Actually go by these pics... Pin 5You can use whatever wire you want. Doesn't have to be a cat anything.
That's quite interesting, maybe even unique. I already have sorbothane sheets, which is a special vibration absorption material similar to rubber but better. Maybe I could try some of that instead, is it the same material? One of them is a fairly thin sheet. But what size of leather hole punch should I get?See attached pic. Pic is of Lexicon preamp while I was packing it up. Look at the caps, the black round material on the gold plated caps is the fo.Q T-102. I used a leather hole punch to get the fo.Q T-102 round. The fo.Q T-102 is micro vibration control material.
IIRC Sorbathane is used as dampening material "between" material. fo.Q dampening tape goes on top of what you want to minimize micro vibrations. I have not experienced micro dampening material better then fo.Q T-102 and T-32 (thinner and more pliable) yet. There are many applications within an audio system that produce positive and audible sonic benefits. Cannot remember the size of the hole punch, they come in a kit of about 10+ sizes. You can just get a size smaller then the diameter of the cap.That's quite interesting, maybe even unique. I already have sorbothane sheets, which is a special vibration absorption material similar to rubber but better. Maybe I could try some of that instead, is it the same material? One of them is a fairly thin sheet. But what size of leather hole punch should I get?
