radical_edward
- Aug 11, 2006
My first post, a short thesis on Grado pads!:
Reverse modded 414s have a bit more bass punch, and are very comfortable.
Bowls have a touch less bass but cleaner mids and highs.
Basically, the bowls leave all parts of the ear directly exposed to the sound, but those with big ears (myself included) may find the pressure edge of the ear uneven due to the way that the bowls sit.
The 414s foam covers more of the ear, which muffles highs a touch, but the comfortable foam provides an even pressure. The smaller cutout means that they focus the bass into the ear canal very effectively.
With my MS-1s, the 414s are the pads I use the most mainly due to comfort. Tracks with prominent kick drums and punchy bass can get right inside your head in an unsettling way with these pads though.
I make/mod a lot of amps and loudspeakers, and like to warm up my ears before analytical listening to new kit, so use MS-1s with bowls and a homebuilt amp.
One last point, bowl pads look stock, but reverse modded 414s scream "Head Fi addict" in bright yellow, so if you want people to come up to you and talk hedphones when you are out and about then the 414s are the way to go.
