inter voice
- Feb 18, 2012
Dear Kevin,
Wether your family member know headphones or not, a sighted test is a sighted test. I'm not arguing you or your family members are hearing something, my comment was wether this difference would still be present in a DBT. It was a personal comment, or a question to self if you will. Now let's put this to rest shall we ?
Back to the discussion, it seems to me the difference in the graph is essentially in the mids, or should I say, the biggest amplitude is in the mids. The graph of Inter Voice is actually different from Innerfidelity as it shows a second difference in the mid-bass region. I'm wondering if that would be repeatable, or if that's a single occurrence quirk. If you haven't already laid your eyes on it, and you have interest in seeing good heaphones measurements, you might want to have a read there :
http://www.innerfidelity.com/content/akg-quincy-jones-q701-sound-and-measurements
@Intervoice, please correct me if I'm wrong, but you did the test for each pair only once, right ?
Just to confirm that I took the measurements more than 10 times, on both right and left channels of the CAN. I also shifted the mic a bit during the measurement and found the high freq. would drop if the mic was near to the bottom or at the top of the ear pad. However the low freq. had not much change even the mic was shifted. The plots I posted had the mic in its middle position just opposite the mini speaker. I found that the FR of both Q and K headphones were very much the same.
If you look at the my plots posted up in my previous threads they were taken at two different dates and the trends for K702 were very consistent and looked very similar.
I believe the measurement equipment I used was different from Innerfidelity and that may explain why the curves were somewhat different. My headphone amp. is Fidelity Audio HPA-200 (with very good freq. response curve and extremely low noise) http://www.fidelityaudio.co.uk/hpa-200.html, the mic is an omi-directional passive mic and the software used is Room Eq Wizard http://www.hometheatershack.com/roomeq/. I used a battery driven Notebook computer to carry out the measurements to avoid any humming noise being picked up. IMHO the FR of my measurement is more realistic especially when you look at my plots for Senn HD650.
