emertxe
Aka: MHOE, MetalHOE
- Aug 11, 2013
Audez'e: There was only one good Audez'e - LCD2 Rev1.
Do not worry, I understand a lot of fun.
But, how can I argue?
Much is not understood. Example:
009 Which technique? what he does with his technique? He is analytical and both musically and in terms of what distinguishes Stax 20 years ago - no comparison.
So, what special technique?
Then Ultrasone. There is not a Ultrasone headphones, which is really good.
Boom, boom, boom, and no man can endure a 10 edition long
Sennheiser HD800: Very good headphones, but a piece of technical sound
Hifiman: Let's give Dr. Fang Biang some time.
Grado: Not for all applications.
T1: 600 ohms - does not fit perfectly for all amps. Sonically not bad, but specific.
Wait just a little. The K812 shows them how it sounds when balance is perfect. And then they also understand what a 009 can not.
I know, the last part wasnt directed at you
This along the "SR-007 being more technically advanced than SR-009" quite scares me... It seems K812 are going to have some more than serious bass, or serious dips in treble region.
Only good audeze is LCD2.1? Cool, so now we know that you know absolutely nothing about audio or audio equipment. You can sign out of head fi at the top of your page, to the right of your username.
Who says that? You? Okay, that's a lot.
You do not know a good LCD2 Rev1. Perhaps you know the ones that were not good.
Maybe they did not understand the topic.
What I have told them about the enumerated headphones, they can stamp. Because it's not complicated.
Exactly like this: A Stax enthusiast knows what an Omega is better than a 009
Cough fleas is not everything in this world. Maybe they need to learn that yet.
Wait: you will understand everything when they hear for the first time with a K812. promised.
if you don't like the 600 ohm T1 grab the T90, almost the same can with 250 ohms and sadly a little more treble.
So there's one of your flaws tackled
and keep in mine Beyer realeased the T1 as 600 Ohm because it was marketed to an AudioPhile market, of which most of us have rather powerful high quality amps. In which 600 ohm headphones mesh very welll
getting on the subject of impedance, I am a little pissed the T90 is ONLY 250 ohms... but... it's not to bad. 250 still makes for a good bit of resitance.
Although my poor 32ohm W1000x is very picky with her amps, due to how sensitive she is. So a TOTL that is low impedance... seems like not that great of a thing
and honestly... the more I think about it, a 250-300 ohm ism can would be the middle ground for impedance. 250 is enough to pair with a powerful amp and still have a little bit of room, while it's also low enough to pair nicely with a Celluar+Amp
Or for us AudioPhiles, the 250 ohm plays nicely with our Hm 801 and DX 100s
... I miss Nomax. He was so cheerful yet not... offense... or too... stupid?
[which guys why haven't we yet?]
600 ohms are ok. There are advantages. Example: Less weight of the coil.
However, they must shoot at 600 ohms, the electrons literally inside - do not get me wrong - but that has to make the amp. Not easy.
The problem is somewhat higher concentration of sound - a little less bandwidth
300 (250) ohm would have been better for the T1. My opinion.
Yeah, Nomax was just the perfect balance.
Also, for teh lulz
Micheal the point of a TOTL is to be complicated, we all like that the HD 800 was built from the ground up, Senn literally started from scratch. That's how a TOT: should be made [unless your Beyer and your building a TOTL from a former Flag Ship, they took a wonderful Dt 880 and fixed all it's issues TADA T1]
ehm, please do provide us with some pics of your Omega and your SR009
other wise we might just start to skip over your posts and ignore you [which guys why haven't we yet?]
well the 250 ohm T1 is the T90, the T90 is literally the same can... except it's cheaper, has less resitance and slighty more treble [which some find to b an issue]
So, what special technique? What do you mean by technique? if your listening to any modern Stax your looking for that effortless precision and speed.
Then Ultrasone. There is not a Ultrasone headphones, which is really good. I have no experience with Ultrasone... no comment...
Sennheiser HD800: Very good headphones, but a piece of technical sound The HD800 is very analytical yes... BUT it can be emotional with the right tube amp
Audez'e: There was only one good Audez'e - LCD2 Rev1. What about the LCD3? I do fancy those...
Hifiman: Let's give Dr. Fang Biang some time. HE-500 is pretty darn good!
Grado: Not for all applications. Ummm PS500/ with or without the G-cush FTW
T1: 600 ohms - does not fit perfectly for all amps. Sonically not bad, but specific. I strongly dislike the T1... no comment...
