Originally Posted by Uncle Erik /img/forum/go_quote.gif
Skip the recable. You'd be able to buy a second pair of headphones for what you'd pay.
Tubes can take the edge off the highs, but it depends on the amp. Some of the the transformer coupled ones roll off in the highs. You might want to look there.
A graphic equalizer would work, too. You could attenuate the highs exactly to suit your ear without spending hundreds to find out if silver sounds thin and brittle, copper is warmer, etc. You could just turn down what you dislike. If you want to save a few bucks, you could simply build a low pass filter to knock out the highest frequencies.
Though I think what would make you happiest would be a pair of Sennheisers.
This is true. From your (the OP's) listening preferences, I can wager that K701's will simply never be your thing. The AKG's sound fantastic with classical music, but fall short for their lack of substantiality with rock music; as you have no doubt discovered.
Personally, I think you should either ditch the K701's in favor of more "inclusive" cans, or consider a supplementary pair to handle rock music. If the
brightness (i.e. excess of treble) of the AKG's is truly turning you off, then be sure to check out Sennheiser's HD600s; which are arguably more well rounded and undeniably warmer in terms of bass. If, however, you dislike the K701s for their
thinness (in other words, the actual treble level is bearable, but the bass and midrange depth are quite comparably lacking) then Grado's wooden models might work well for you. They're certainly specialized in terms of "compatible" genres, but are arguably unparalleled in that niche.
Personally, I think you'd be wasting your time with cable upgrades, and even more-so with hopes of burn-in improvement. Changes in both cases, if present at all, are subtle; to me at least, you can't alter the
sound signature (which you find at fault here) with cables or burn-in.
