owatito
- Jan 5, 2013
Very good description. It's so good for solo piano, really 3D-like.
Mine is all stock (bass light or neutral, not sure what versions there are).
The fit isn't quite right. I think I need to put some sort of pad under the headband to make it level to my ears. Has anyone had a similar problem?
yours leagues have factory or stock?, if so, I guess this should pretty worn, and that's why they do not fit well, not if you refer to that?
Anyway I let a mod that I did (in case you need it later), it is easy and cheap.
I leave the link, is a Spanish site, but if you have any doubt, will answer your questions possible taste.
http://www.auriculares-hifi.com/foro/index.php?topic=1533.0
Greetings.
