- Aug 5, 2012
Zero hiss from my AK380 amp with JHA Laylas.
I'm delighted with mine. No hiss whatsoever on any headphone.
Hello All,
I'm new here and I just bought AK 380. My question is :
- How is important the AK380 Amp for A&K 380? you can hear a lot of diference in the sound? in micro dinamics? or it's only for more power?
Thanks .
I don't see any advantage beyond a little more power actually...
The sonic differences between amp and no amp are very small. I imagine I could not guess which was which in a double blind test.
The amp has the advantage of opening up a wider range of headphones and earphones to you.
The main disadvantage is you cannot use the charging dock with the amp in place and the amp is fiddly to install and remove.
Battery life does not appear to change with or without the amp attached.
Can I say with the AMP the 380 drives all head/earphones easily
