dsavitsk
MOT: ECP Audio
- Aug 3, 2003
Yup, I've done the math a ton of times, but in practice it never works. If you don't insist on the regulator, use super low dropout diodes, and don't mind significant ripple, you might pull it off. I did it with a CRC filter with each C = 22000uF and the R = 0R39, and just got enough voltage, and that was to only run one heater. Adding 3 more drops it more, and increases ripple.
No, you use your method when you are using a ful wave rectifier, but here we are using a bridge. Now get back to work.
Originally Posted by AndrewFischer /img/forum/go_quote.gif That's not quite true. Since 4 tube heaters are a more or less constant load, an unregulated DC supply will work. With no load, the output will be about 1.414*6.3 - voltage drop across the diodes. Somewhere around 8VDC. |
Unless im mistaken, i believe that math is wrong. To calculate the RMS voltage (that is, the DC voltage youre going to get off of an AC line) you divide the peak voltage (in this case, 6.3v) by the square root of 2, not multiply it. |
