BoilermakerFan
- Jan 2, 2008
It's not that you can't power multiple devices off one transformer; it's the issue that you +/-12-15V for the VSPS and 0-24 or 0-48 for the Aikido. If you wanted to limit yourself to 24V on the Aikido you have a much more limited tube selection, but you could order a 100-200VA toroid with dual 12Vac secondaries and pull the 24Vac for the Aikdo from a series connection and the 12Vac for the VSPS, but I would definitely use a filtered IEC socket and fuse each PSU separately, on both legs. You'll still have the chance for more noise, you might be splitting hairs too if your power is good and your ground is good.
The 6GM8 cannot be run at 48V.
Other novals include the 12au7a (150V), 6922(48-170V), 6DJ8 (48-170V), 6h30(48-200V), 6n6p(100-200V), 6n1p(200-250V), 6cg7(200V), and 12BH7(48-250V). I would start with the 6DJ8/6922 and 12BH7 tubes at 48V first... There are a lot of nice options for sourcing new 6922 tubes too, so that makes them easier to find and you can get crazy and buy matched cryo'd sets for less than some of the 6GM8 or 6h30pi tubes...
There are actually a lot of other noval options, but their gains are just to high, most between 50-100, which could be great for 1V CDPs, or MCs run through 40dB phono stages if the noise is kept in check, but probably not good for most other applications.
