SchneiderStudios
- Nov 29, 2008
Our rev is up if you guys wanna check it out!
http://gdgtmac.co/M7bOIp
I just take of a piece from a cotton ball, roll it between my hands and take off the ear pads, place the cotton and put them back on. I don't use any eq pre sets with them I do sometimes use them with a e17 for my portable rig.
I don't know for sure, but from the looks of the pictures, it looks like the pads are similar to the ones given on the new TMA-1 Studios. Except it looks as if the hard foam (PU Foam) pad is a lot thinner (probably the same thinness of the leather pads that come with the Studios). If so, you might be able to swap them out. IDK though. I may eventually try to get a Capital, but busy reviewing the Studio right now.
The pads aren't interchangeable on the Capital and they are the same as the huge cup style pads on the Studio, but a lot more firm. They aren't hollow or thin.
Aiaiai kind of made these pads on the awkward size because they feel like at some point they cover your ears entirely yet leave a lot of space in between too which for some people it'll create a bad seal; and so you lose the thumpyness of the bass and detail. They don't immediately create a suction like the TMA-1 do.
They are removable but don't have the same mounting so you can only replace them with another stock pads. The Studio aren't supposed to have any suction.
beguiling musicality.
Cheers,
Andy.
