After a year with Grados, i finally think they *are* bright 'phones
post-167325
Thread Starter
Post #1 of 15
erikiksaz
After reading for countless hours before buying my sr325s, i have just realized, a whole friggen year after buying them, that they ARE bright. I was listening to Korn with my Etys, when i decided that i feel more like an open can, so i threw on my Grados. Soon enough, i started to hear what i believe you guys describe as "bright" sound/music. How strange, huh?
post-167369
Post #3 of 15
erikiksaz
CHA47. Ahh, even though they're bright, i still love 'em to death
post-167374
Post #4 of 15
rawhit
erikiksaz
I also think that my SR-325s are on the bright side. But dont find them fatiguing.
But there are ways to reduce brighness of the cans. I would be getting a creek obh11se soon which is considered to be on the warm side and supposedly has a good synergy with grados.
Also pads make a lot of difference. Comfy/flat pads reduce the treble energy a bit compared to the bowl pads.
cheers
RawHit
post-167375
Post #5 of 15
CRESCENDOPOWER
Originally posted by rawhit
erikiksaz
cheers
RawHit
Grados are only bright in comparison to some other headphones. As for the Creek OBH-11SE, I wish the hell someone would decide once, and for all whether this amp is analytical, or warm!
post-167382
Post #6 of 15
KR...
Curator of the Headphone Lust Museum
The CHA47 is a bright amp, so there you go! When paired with the right amp, they shouldn't sound bright.
[size=medium]System synergy is the key to creating a great audiophile system![/size]
post-167385
Post #7 of 15
sTaTIx
I like my headphones/source combo the way it is right now, and was thinking of getting the Creek OBH-11, but if what you say is true, that the Creek is on the warm side, than would adding a Creek cause the sound to be warmer? I was hoping that it wouldn't do anything to the top-end, because I don't want it any warmer!
post-167390
Post #8 of 15
rawhit
crescendopower & statix
unfortunately I cant audition the creek (or most amps for that matter) before buying so I cant comment on whether its analytical or warm.
I have decided to try the creek based on most comment that it matches well with grados.
I will post what I think about the amp after I have spent some time with the unit.
greetings
RawHit
post-167393
Post #9 of 15
millerdog
They are bright! but don't you think they reveal things you wouldn't have heard.
On the other hand, their brightness hides some mids and vocals.
Just my thoughts,
md
post-167409
Post #10 of 15
Magicthyse
Better to look good than to sound good!
Don't have the 325 so can't comment - every Grado phone seems to generate totally different reviews while people almost unanimously say they like them... Weird.
I've seen the SR225's being described as 'bright' and 'dark' in the course of one day searching for reviews.
I've seen the SR60's being criticised for 'no bass' by HD280 owners (they have very similar bass in a quiet room), while others say the bass is great...
It just goes to show, go with what you like.
post-167508
Post #11 of 15
a1leyez0nm3
the only grados that i have heard and remotely liked were the rs1's... and I would much rather have the etys instead. most seem bright tho.
post-167656
Post #12 of 15
NotoriousBIG_PJ
Step 1: Plug power cable into wall. Step 2: Plug other end of power cable into....umm.... Step 0.5: Order something to power with power cable.
Whats the difference between warm and dark?
Biggie.
post-167690
Post #13 of 15
kajohndet
While I still owned SR60, I found that Headroom crossfeed helped reduce its brightness a lot, bass was improved and mid sounded thicker. I think Grado works well with Headroom amps.
John
post-167706
Post #14 of 15
Duncan
Moderator
Strange KR... Personally I find the CHA47 to be quite dark sounding when compared to my META42, and seemingly neutral sounding when compared to my X-Can V2... what are you comparing the CHA47 against?
Oh... to keep on track within this thread, I have the SR125, and really don't like them for how bright and thin they sound... ho-hum
post-167707
Post #15 of 15
Duncan
Moderator
Biggie.
From my understanding, the term warm, is used when the midrange is on the positive side of neutral...
and dark, is when the treble is on the negative side of neutral
