neilvg
- Jun 10, 2004
I think your right for the most part - BUT, I will add that while sibilance is a necessary and normal part of a recording, it is the way that the sibilance is handled by a playback system (...and recorded too for that matter) that makes a difference. As I stated earlier, sibilance need NOT, not be euphonic (attn-double negative). Also, what seperates some of the lesser (yet still resolving and dynamic) systems from the top tier group is the way in which they handle these sibilant transients and the like. On my home rig - both headphone and speaker, I have carefully sorted out and found the equipment which created a poor sibilant reproduction. Listen to the way sibilants sound when you say them, or when someone is normally speaking. They shouldn't sound searing or overwhelming (unless recorded this way), they shouldn't be smeared or underpronouced either. Unfortunately, only either very nice systems, or very modest systems (which tend to be euphonic but not much else), really handle siblants acceptably for me - with the higher end ones actually doing it right.
Of course these issues become more of an issue at 'realistic' listening levels. But then again, the level that you listen at comfortably also has to do with the fact that certain offending frequencies will often times be the culprit for finding a lower volume, and not the fact that the entire spectrum was outputting too much energy.
Neil
Originally Posted by Zenja /img/forum/go_quote.gif Sibilance is definitely caused by the music itself (look at the spectrum analyzer when it appears, there's a massive mountain centered at around 8-10kHz) and to reduce/get rid of sibilance would mean to reduce sounds that are supposed to be there. It doesn't seem like there's much that can be done about it if you want a neutral tonal balance. It doesn't really bother me anyway. If it's to the point that it does bother me, it means I'm listening to loud. |
Neil
