Hello fellow DIY Aegis builders/owners and
@L0rdGwyn. First off, I'd like to just say that I am absolutely in love with the sound qualities of my DIY Aegis (built by
@mchuckp) and this post is really just a plea for help/ideas as I've got one issue with mine that I can't seem to get rid of. What problem is that? Noise. Not a hum, but what sounds like a low level electrical noise or static. This CANNOT be heard while music is playing, but can be heard between tracks (but you do have to listen for it many times). It is not specific to left or right and does not appear to go away based on different tubes or by swapping input/output tubes from left to right or a rectifier tube swap. It also does not increase in volume as the volume dial is increased. The noise is NOT present at all until an input to the Aegis is turned on. (Regardless of input source) What's also strange is that it seems to increase in volume the longer Aegis is left on, but again does not become so loud that it overpowers the music itself in any way. I would also say (and this could be just one ear being more sensitive than the other) that it seems "slightly" louder in the right channel vs the left.
Here is what I'm using in my chain. Node 2 -> Schiit BiFrost 2 -> Aegis -> Atrium Open
Things I've tried so far:
- Moving Node 2 away from Aegis
- Putting all equipment plugs on single surge protector plugged into one outlet
- Plugging Aegis into outlet by itself separate from other items
- Using all three items on a separate circuit in my house
- Removing plugged in items like computers/basement fridge from the same circuit Aegis was using
- Different power cords for the Bifrost and Aegis
- Plugging all three into a Belkin power conditioner
- Plugging Node and Bifrost into Belkin with Aegis into the outlet directly
- Different tube combinations
- Replacing COAX out from Node to Bifrost with optical from Node to Bifrost
- Different sources for input including Node directly into Aegis, Bifrost into Aegis or old DVD player into Aegis
- Different RCA cables
- Making sure my phone is a good distance from Aegis.
I feel like my last remaining option is to take the Aegis and my input gear to another location (other than my house) and try it on their power to see if perhaps it just may be an issue with the power at my home unless you all can think of something else. Or maybe you can just tell me this noise is inherent in tube amps and I'm overanalyzing it. For reference (as I think
@mchuckp did a really nice job on the construction of the Aegis), maybe he can post an internal photo of the unit as well.
