Aegis DIY Tube Headphone Amplifier
May 22, 2024 at 7:42 AM Post #2,446 of 2,631
Yeah, still available... the only trouble I've seen was with Woo amps where the circuit wasn't performing exactly as required for the 274b. It would flash bright on startup I think and potentially blow the filament. Not sure of the exact technical problem but it seemed to only be related to how Woo amps operated. For those amps it was recommended to use ER5U4G.
Other than that there was the quality control issues prior to Thomas taking over but he sorted all that out quite a while back now. The 274b & 274a are both listed on Elroy's website as well as being sold via the UK distributor. I'd imagine that will be the same in the US. Certainly haven't seen anything about them being pulled.
Got ya, and I believe Thomas is only selling direct now by the way. Perhaps some old distributors might still have some inventory, but I believe you have to buy straight from Thomas now. I have had the Elrog ER300B's in the past, so I am very familiar with Thomas and the amazing sound of his tubes, and I am sure the 274b is incredible.
Curious for reference, what version of Mullard GZ34 do you have?
I think it would be an interesting comparison between the ER274b and Phillips Holland GZ34, as I think those two are going for the same type of sound sig. . .linear, dynamic and open with textures galore.
May 22, 2024 at 8:15 AM Post #2,447 of 2,631
Just the standard GZ34 unfortunately. It would make for an interesting comparison.
A word that jumps to mind when I first heard the ER274b was expansive... the sound felt big. More balanced across the range so I guess more linear when compared to something like the Brimar 5R4GY that has great bass texture but not as extended as the ER274b. The 274b also has more weight that the standard GZ34. I would struggle using the GZ34 with Mullard EL38's as it felt a bit edgy... possibly smoother or sweeter highs for the Elrog. I wish I was better at describing these things with proper audio speak 😀
If I'm listening to an acoustic guitar, after the string is plucked the sound would carry more with the ER274b. Other tubes felt like it cut the note short. You could feel the friction of a violin bow across strings more with the 274b and pickup on small movements of the artist as they move around. Perfect timbre, even with classical piano albums. I think what I like most is it just sounds more real. You can feel the resonance when they come down hard on the keys as the sound reverbs around the wooden frame.
May 22, 2024 at 9:07 AM Post #2,448 of 2,631
I think you are doing a fantastic job of describing what you hear, and I appreciate the info.
May 22, 2024 at 10:53 AM Post #2,449 of 2,631
What wire do you have available? 20awg is probably the most common size of hookup wire made. You could use 18awg for the output and rectifier tube heaters and 22awg for everything else
For what part of the circuit?
Can we use 18 awg or 20 awg for everything ?
May 22, 2024 at 10:59 AM Post #2,450 of 2,631
May 23, 2024 at 6:18 PM Post #2,451 of 2,631
Today the right channel on my aegis went out randomly :cry:, I tried swapping all the tubes and still no dice.
I just went through the tests at the end of the guide. All of the resistance ones were OK, but here are the voltage tests:
TP5 = 167 volts
TP6 = 200 volts
TP9 = 105 volts
TP10 = 190 volts
TP15 = 40 volts (What)
TP16 = 6 volts
TP17 = 1 volts
TP18 = 2 volts
Any ideas @L0rdGwyn ?
Thanks in advance!
May 23, 2024 at 6:25 PM Post #2,452 of 2,631
TP5 = 167 volts
TP6 = 200 volts
TP9 = 105 volts
TP10 = 190 volts
TP16 = 6 volts
TP17 = 1 volts
TP18 = 2 volts
Thanks in advance!
It's another failed 400V Jupiter Copper Foil cap. C4 is the bad cap, it's shorted. Don't leave the amp on, the right channel output tube is running at high current because of the short. I'd replace both caps. If you want to use Jupiter, go with the 600V version, or you could do the V-Caps I put as an alternative in the BOM. Or something else as long as it fits!
May 23, 2024 at 6:29 PM Post #2,453 of 2,631
That was what I was leaning toward, thanks for clarifying! Appreciate ya!
May 23, 2024 at 6:31 PM Post #2,454 of 2,631
No problem. Bummer those caps aren't reliable, clearly they are not rated to 400V, Aegis comes nowhere near that...
Apologies in advance if this happens to anyone else.
May 23, 2024 at 6:39 PM Post #2,455 of 2,631
I may just proactively replace mine. It seems that their reliability issues are fairly significant.
May 23, 2024 at 6:50 PM Post #2,456 of 2,631
Well assuming some 30 or so DIY Aegises (I'm not certain of that number, ballpark), and four instances of this occurring, that's 4 out of 60 caps, around 7%. Two of the four cases arrived bad and the issue was seen at first turn on, two occurred after about a year. My feeling is most will be fine, but I can't say for certain.
May 23, 2024 at 6:50 PM Post #2,457 of 2,631
I was just thinking this. Is it worth proactively replacing? Also how much work would be involved in replacing them? We would pretty much have to fully remove the board right?
May 23, 2024 at 6:53 PM Post #2,458 of 2,631
I replaced my Jupiter caps with V-cap ODAMs. It does not require removing the board, just some de-soldering tools (solder sucker and braid). You can probably get away with just carefully heating each connection and gently pulling on the wire with needle nose pliers. It's really pretty easy.
May 23, 2024 at 6:55 PM Post #2,459 of 2,631
You can do it without removing the board. Clips the leads of the caps and remove the body. Heat the solder pad of the leads with a soldering iron and gently pull the lead out with needle nose pliers. Key here is gently, don't pull hard, you don't want to damage the solder pad. Remove any excess solder on the pad with a soldering wick. Put the new caps in and solder from above. Make sure you clip any excess lead length from the new caps before you put them in so the lead doesn't go through the PCB and make contact with the chassis on the other side.
May 23, 2024 at 7:00 PM Post #2,460 of 2,631
Nice. Good to hear that you don’t have to remove the board. Curious did you notice any sonic differences after swapping the caps?
Awesome thanks for the info. Although on the other hand kinda feel if it ain’t broke don’t fix it. Since it’s easy to replace then should it fail then replace it
It’s about 10 months now that I’ve built the Aegis and so far everything is working well
