mchuckp
@L0rdGwyn,That's fine, very much within tolerance.
I guess I really screwed something up as none of my readings for test points 5-18 checked out and some way out of whack. Frustrating since I tried to be very meticulous. Below is what I got. You will see multiple tests for TP5 & 6 as I tried some different tube combos to see what would happen. The Tung Sol's are new stock from a reputable seller. The KT88s are also new stock but have been used a lot in a different amp years ago. The rest are old stock from sellers with high ratings but new to me for this amp. I'm also attaching a pix of my build. I took a bunch of pix along with way if there is something you'd like to see or I can take more close up of finished build. So much for listening to my amp today.
Tubes Used | ||||||
Test Pt | DCV | Range | Rectifier | Power | Input | Comments |
TP5 | 163 | 225-275 | RCA 5R4GY | RCA 6V6 | Tung Sol 6SL7 | |
TP6 | 188 | 225-275 | 5R4GY Both RCA | RCA 6V6 | Tung Sol 6SL7 | |
TP5 | 138 | 225-275 | RCA 5R4GY | GL KT88 | Tung Sol 6SL7 | KT88s are well used |
TP6 | 164 | 225-275 | RCA 5R4GY | GL KT88 | Tung Sol 6SL7 | KT88s are well used |
TP5 | 144 | 225-275 | Brimer 5R4GY | RCA 6V6 | Tung Sol 6SL7 | |
TP5 | 166 | 225-275 | WH 5R4GYB | RCA 6V6 | Tung Sol 6SL7 | |
TP9 | 102 | 220-270 | WH 5R4GYB | RCA 6V6 | Tung Sol 6SL7 | |
TP10 | 180 | 220-270 | WH 5R4GYB | RCA 6V6 | Tung Sol 6SL7 | |
TP15 | 29.3 | 6-14 | WH 5R4GYB | RCA 6V6 | Tung Sol 6SL7 | |
TP16 | 5.5 | 6-14 | WH 5R4GYB | RCA 6V6 | Tung Sol 6SL7 | |
TP17 | 1.2 | 2-3 | WH 5R4GYB | RCA 6V6 | Tung Sol 6SL7 | |
TP18 | 2 | 2-3 | WH 5R4GYB | RCA 6V6 | Tung Sol 6SL7 |
